Items with no label
3341 Discussions
MATLAB RGB point cloud
JBos3
I would like to acquire and plot RGB colored point clouds from a D435 in MATLAB. The desired output is analogous to the rs-pointcloud.cpp example.
I reviewed rs-pointcloud.cpp and the MATLAB wrappers, and I'm able to acquire a point cloud, however I can't find how to properly color and plot the point cloud. Below is my code, which I hope will be useful to others.
There are two options that I'm considering:
1) is there a way for MATLAB to consume the realsense.pointcloud() object directly?
2) Assuming the answer to 1) is no, can I access and use the vertices and textures to reformat the RS point cloud object into a MATLAB point cloud object?
points.get_vertices(); and points.get_texture_coordinates(); seem to get correct values, but I'm not sure how to use them in MATLAB.
Thanks!
MATLAB:
% Make Pipeline object to manage streaming
pipe = realsense.pipeline();
% define point cloud object
pcl_obj = realsense.pointcloud();
% define colorizer to give point cloud color
colorizer = realsense.colorizer();
% Start streaming on an arbitrary camera with default settings
profile = pipe.start();
% Get frames. We discard the first couple to allow
% the camera time to settle
for i = 1:5
frames = pipe.wait_for_frames();
end
% Stop streaming
pipe.stop();
% Select depth frame
depth = frames.get_depth_frame();
% get point cloud points without color
points = pcl_obj.calculate(depth);
% get texture mapping
color = frames.get_color_frame();
% map point cloud to color
pcl_obj.map_to(color);
% get vertices (nx3)
vertices = points.get_vertices();
% get texture coordinates (nx2)
tex_coords = points.get_texture_coordinates();
VHess
I made this code that I thinks solve this problem:
% Make Colorizer object to prettify depth output
% Start streaming with default settings
align_to = realsense.stream.color;
alignedFs = realsense.align(align_to);
% Get streaming device's name
dev = profile.get_device();
name = dev.get_info(realsense.camera_info.name);
for i = 1:5
fs = pipe.wait_for_frames();
end
%create a point cloud player
player1 = pcplayer([-1 1],[-1 1],[-1 1]);
frameCount =0;
while isOpen(player1) && frameCount < 2000
  frameCount = frameCount+1;
  %align the depth frames to the color stream
  aligned_frames = alignedFs.process(fs);
  depth = aligned_frames.get_depth_frame();
  color = fs.get_color_frame();
  %get the points cloud based on the aligned depth stream
  pnts = pcl_obj.calculate(depth);
  colordata = color.get_data();
  colordatavector = [colordata(1:3:end)',colordata(2:3:end)',colordata(3:3:end)'];
  vertices = pnts.get_vertices();
  view(player1,vertices,colordatavector)
end
% Stop streaming
pipe.stop();
Hello jjbos,
Thank you for our interest in the Intel RealSense D435 camera.
Please make sure that you have the latest firmware on your camera and librealsense version 2.16.1.
We have modified your code (it follow the export_to_ply python examples).
function pc_example
pipe.start();
for i = 1:5
end
% get color frame
%export ply file
pnts.export_to_ply('pc_example.ply',color);
pipe.stop();
end
Please let us know if this works with you as well!
Eliza
JBos3
Hi Eliza,
Thank you. This is helpful, and *almost* what I need.
I would like to visualize the colored point cloud live stream, just like the rs-pointcloud.cpp example... but in MATLAB.
Is there a way to convert the RealSense point cloud object to something MATLAB can manipulate without having to write and then read an intermediate .ply file?
-Joe
Hello jjbos,
You check out this post that I believe can help you with your project: https://www.mathworks.com/matlabcentral/answers/7202-processing-on-a-live-webcam-streaming-video https://www.mathworks.com/matlabcentral/answers/7202-processing-on-a-live-webcam-streaming-video. Please note that you might need the Image Acquisition Toolbox.
Thank you,
Eliza
JBos3
Hi Eliza,
Thanks for looking but this does not address the issue. The link you sent relates to processing 2D images. Please correct me if you saw something related to point clouds.
Again, I need to convert the RealSense point cloud object and other data (e.g. pc.vertices, pc.texture, color image, depth image) into a MATLAB point cloud without going through an intermediate .ply file. MATLAB requires point cloud vertices and RGB values for each vertex.
It appears I can get the correct vertices from the point cloud object but I don't know how to get the corresponding RGB values to color the point cloud. Can you help with this?
-Joe
Here is how I get the point cloud vertices (x,y,z values), but again I need the corresponding RGB values:
% Get frames. Discard the first several to allow
for i = 1:5
end
Hello jjbos,
The RealSense team is working on an example to demonstrate how to do this but I don't have a timeline for when it will be completed. Meanwhile, you can check out this code: https://communities.intel.com/community/tech/realsense/blog/2018/10/03/unofficial-pointcloud-stream-viewer-in-matlab https://communities.intel.com/community/tech/realsense/blog/2018/10/03/unofficial-pointcloud-stream-viewer-in-matlab.
We need to figure out how to use the pcshow command and to use the same algorithm in the align.cpp example to make the depth and color frames the same size.
Jesus G.
Intel Customer Support
JBos3
Thank you. I very much look forward to the colored point cloud example in MATLAB.
-Joe
VHess
for i = 1:5
end
frameCount =0;
end
% Stop streaming
pipe.stop();
Pcmehdi
Hello VHess,
I run your codes but I have faced an error as below:
Error using realsense.align
Error: File: align.m Line: 4 Column: 1
Illegal use of reserved keyword "classdef".
Error in realsense.VHess (line 21)
I am using Matlab2020b!!
Do you have any idea what the issue might be?
SVerg
Hello! I have a problem with the code, the function
alignedFs = realsense.align (align_to);
(Error using realsense.align Error: File: align.m Line: 9 Column: 20 A constructor call to superclass realsense.filter appears after the object is used, or after a return)
Apparently there is an error in the code of align.m, could you help me with this matter? I would greatly appreciate it.
S.V.I
JBos3
Thanks VHess! Works like a charm. Cheers.
SonuMathur
In which for you save the point cloud...?
VHess
@SVerg​ I had to comment out validateattributes on line 17 in align.m to get it to work, but I'm not sure if that is related to your issue.
