Items with no label
3341 Discussions
Mapping a Pixel to a 3D Point by Deprojecting
ARafi4
I am trying to map from a pixel to the point where it is located in 3D space, and by looking at librealsense on GitHub, it seems that the function rs2_deproject_pixel_to_point() is exactly what I need. However, I am unsure of how I can get a specific pixel from an image as well as the depth data for that image.
From the hello-world example, I can see that you can get the distance to the center of an object by using get_distance() with half of the width and height of the frame as follows:
// Try to get a frame of a depth image
depth_frame depth = frames.get_depth_frame();
// The frameset might not contain a depth frame, if so continue until it does
if (!depth) continue;
// Get the depth frame's dimensions
float width = depth.get_width();
float height = depth.get_height();
// Query the distance from the camera to the object in the center of the image
float dist_to_center = depth.get_distance(width / 2, height / 2);
Is this the best way to do it? What if I want the pixel located at [0][0] in the frame? I think this would be easier for me if I can convert a frame to a 2D array so I can address each pixel specifically rather than using a fraction of the frame's height and width. Thanks for any help.
jb455
Valued Contributor II
It'll probably be easiest for you to use the Point Cloud class. There is an example here: https://github.com/IntelRealSense/librealsense/tree/master/examples/pointcloud librealsense/examples/pointcloud at master · IntelRealSense/librealsense · GitHub.
This generates a 1D array of 3D points so to access a specific pixel (x,y) take the (x + y * depth.get_width())th element of the vertices array.
If that's too much overhead and you really only want a single pixel each time, the get_distance method works with (x,y) coordinates as inputs (so get_distance(0,0) will be the first pixel). There is a warning in one of the samples that calling get_distance many times might not be very efficient, so if you do want more than a few pixels it's probably best to use the point cloud.
jb455
ARafi4
Yes, I eventually want to do this for every point in a certain object and average them to the 3D center of the object, so I will use Point Cloud as you suggest. However, I tried to run this example and it didn't seem to work as there were a few compile-time errors; perhaps I messed it up by accident. But that doesn't matter what I am doing anyway.
What does depth.get_width() do? Is it getting the z coordinate for a pixel int the depth frame of width w? Does frames.get_depth_frame() return a 1D array each with a specific width? I was imagining that it would return a 2D array which would mean that there would be multiple pixels with the same width.
Thanks for all the help. I will try this out.
jb455
depth.get_width() should return the pixel width of the depth image (I use C# not C++ so I'm going by the samples!)
The data is stored row-by-row, so the first 640 elements (assuming a 640*480 image for example - in this case get_width should return 640) represent each pixel in the first row, then the next 640 are the second row down etc. So if you want a pixel in the third row (y=2), you need to skip the first 640*2 elements to get to the start of that row, then add whatever your x value is to the index to move across the image. Hence [x + (y * width)].
