Items with no label
3340 Discussions
Mounting Realsense D410 depth module and D4 vision processor
TPlan1
I have the D410 depth module, a D4 vision processor, and a D400 rigid 50 pin interposer and I am trying to find a stable method to holding them together and mounting them.
The Intel Realsense D400 series datasheet mentions specific mounting brackets on page 75. Are these perhaps brackets for sale or is there perhaps a better alternative?
What is a good approach to mounting the D400 series depth modules combined with the D4 vision processors?
Thank you!
MartyG
The bottom of page 75 of the data sheet has details for ordering the brackets.
FASPRO Technologies, INC. Chuck Drews
mailto:chuck@acuproinc.com chuck@acuproinc.com
https://fasprotech.com/ https://fasprotech.com/
(M) 847-612-2350
(O) 224-848-4131
In regard to alternatives .... Intel's online Click store has a pre-made protective enclosure in the drone section of the store that was designed for the older RealSense R200 model. You may be able to retrofit this for a D410 module, and have installation space to spare (the module has a space for installing a single-board computer too). This solution may be too bulky for your needs though.
The most obvious difficulty with such an adaptation would be that the camera cover plate's lense holes would not line up with the imager positions on a D410 camera.
https://click.intel.com/intel-aero-platform-for-uavs-enclosure.html Intel® Aero Platform for UAVs Enclosure
A simpler mounting option is a magnet, similar to the strong magnet on the back of the R200 model for mounting to surfaces such as monitors.
