Items with no label
3341 Discussions
Multicam in C# -- processing the frameset
SChop3
Hello, I'm looking at processing the data from multiple cameras in C# and I have a few questions with regards to the appropriate way of processing the dataset.
With a single camera
When there's only a single camera connected, I use the Pipeline class to get a frameset
pipeline = new Pipeline();
cfg = new Config();
PipelineProfile profile = pipeline.Start(cfg);
frames = pipeline.WaitForFrames();
depthframe = frames.DepthFrame;
colourframe = frames.ColorFrame;
To align the colour frame to the depth camera I use the Align class on the resulting frameset
FrameSet colourindepth = align.Process(frames);
With multiple cameras
Using code snippets from the examples, for multiple cameras I'm using a different approach. (Code simplified for brevity)
using (var ctx = new Context())
DeviceList cameras = ctx.QueryDevices();
// For now, going to loop through the cameras
foreach (Device camera in cameras)
FrameQueue depthqueue = new FrameQueue();
FrameQueue colourqueue = new FrameQueue();
SensorList sensors = camera.QuerySensors();
Sensor depthsensor = sensors[0];
var depth_profile = depthsensor.VideoStreamProfiles.First();
Sensor coloursensor = sensors[1];
var colour_profile = coloursensor.VideoStreamProfiles.First();
//Start sensors
depthsensor.Open(depth_profile);
depthsensor.Start(depthqueue);
coloursensor.Open(colour_profile);
coloursensor.Start(colourqueue);
// Receive frames
Frame colourframe = colourqueue.WaitForFrame();
Frame depthframe = depthqueue.WaitForFrame();
Questions
However, in this case I only fetch a single 'Frame' object at a time. How do I align the colourframe to depth?
I've tried to use the .waitforframeset method but it doesn't seem to be supported for this method. Also, the Align class requires a Frameset object?!
How do I get a frameset in this instance? Should I be using a pipeline to get the frames? Do I pass the handle to the camera when constructing a new pipeline?
Any help would be greatly appreciated
SChop3
Hello all,
I've worked on this looking for a workaround and have found that the key is to stick with the pipeline method. The configuration class allows you to create a custom pipeline based on a camera's serial number
I'm still starting with the camera context as before but this time I'm using a pipeline with a specified camera
  1. using (var ctx = new Context())
  2. {
  3. DeviceList cameras = ctx.QueryDevices();
  4. // For now, going to loop through the cameras
  5. foreach (Device camera in cameras)
  6. {
  7. cfg = new Config();
  8. cfg.Enabledevice(camera.Info[CameraInfo.SerialNumber])
  9. PipelineProfile profile = pipeline.Start(cfg);
  10. }
Then, when you use that profile object to wait for frames, it will wait for frames from the specified device and give you a frameset you can use in an Align object.
If anyone else is using C# for multicam I'd reccomend this approach.
Apologies if the code is slightly wrong, it's from memory.
SChop3
Hello all,
  2. {
  6. {
  10. }
MartyG
Thanks so much for sharing your results with the community, Wiredchop! C# resources are always especially welcome.
