Items with no label
3332 Discussions
My son received a warning trying to play Star Wars Battlefront II that out of date Intel Drivers were detected, update at http:downloadcenter.intel.com
BKane2
The message is generic and doesn't say which driver is out of date only that 10.18.10.4276 08/17/2015 was detected and xx.xx.15.48 or later is recommended. How do I know which grouping of drivers to search, thanks
AlHill
What is the model number of your NUC?
Doc
BKane2
How can I find the number of my nuc
AlHill
No problem. Just Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
BKane2
thanks, Hope this provides the required info. There are many "Not Available" in the specs.
AlHill
Ok, you do not have an Intel NUC, which is what this forum is for.
You have a Dell Latitude E6430.
https://www.dell.com/support/home/en-us/product-support/servicetag/0-Y004ek9zeUdZZHhyUVlCSTM4ZGFTQT090/drivers
The latest driver for your processor can be found here, under drivers and software. Look for graphic driver 15.33.50.5129
https://ark.intel.com/content/www/us/en/ark/products/64896/intel-core-i5-3320m-processor-3m-cache-up-to-3-30-ghz.html
Doc
