Items with no label
3340 Discussions
Need application utility to do remote system update through Ethernet
sRama28
hi
i am doing remote system update in MAX 10 FPGA with NIOS processor through Ethernet.
i am following AN741 document for this . i have a sample project MAX 10 RSU though UART and software utility (knightrider.exe)
like above i need Ethernet based software utility to send RPD file to internal CFM flash memory.
Please share application utility to send my file ASAP.
thanks in advance.
AlfredoS_Intel
Hi sRama28,
Thank you for posting in our Intel® Ethernet Communities Forum.
We need to transfer your thread to the correct forum.
Alfred S
Intel Customer Support
JohnT_Intel
We do not have the example design to performed it directly but you may refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an429.pdf which is performing Remote Update with Ethernet and merge it with AN741 design example.
The AN429 will provide you the guideline on enabling the data transmission to be send through Ethernet.
