Items with no label
3341 Discussions
No module named pybackend2
NeuroGalaxy
I am trying to run a python example. it uses a module called pybackend2. I tried running the example but it displays a module not found error. I am using the pyrealsense2 library for python. I am using Intel Realsense D435. I dont know how to install this module. 'import pybackend2 as rs'
Eliza_D_Intel
Hello NeuroGalaxy, Thank you for your interest in the Intel RealSense D435 camera. I have provided a solution for this issue on https://forums.intel.com/s/question/0D50P00004EgktP/enable-autoexposure-using-python-code In order to avoid redundancy, let's continue the conversation there! Thank you and best regards, Eliza
Eliza_D_Intel
