Items with no label
3341 Discussions
Physical dimesions of Realsense R200
TKirv1
New Contributor II
Hello all,
Are the specific dimensions of the R200 model available? Specifically I would like to know the distances from one end of the module to the center of each of the 3 cameras. I am building a mount for the realsense that sort of clamps it in the middle, and I wanted to be sure the clamps don't obstruct any of the cameras' FOV's.
Thank you!
Thomas
MartyG
The front glass obscures the innards, so it's hard to tell the distance between the cameras. If you use the internal drawing below as a guide though, you can see there's quite a distance between the cams in the middle, so it should not be too hard to estimate where to put a mount without obscuring a camera.
MartyG
TKirv1
New Contributor II
