Items with no label
3341 Discussions
Point Cloud Example
JTray
I am just trying to run the point cloud example that comes with the binary sdk 2.1 (most recent binary) install in visual studio but I am getting a build error to do with a function it is using in example.cpp. (Does not take 4 arguments)
draw_pointcloud(app.width(), app.height(), app_state, points);
The function in example.cpp is as follows which only takes 3 parameters. Am I missing something? Is there a problem with the binary install 2.1 SDK? Anyone able to shine a light on this? Thanks
// Handles all the OpenGL calls needed to display the point cloud
void draw_pointcloud(window& app, glfw_state& app_state, rs2::points& points)
if (!points)
return;
// OpenGL commands that prep screen for the pointcloud
glPopMatrix();
glPushAttrib(GL_ALL_ATTRIB_BITS);
float width = app.width(), height = app.height();
glClearColor(153.f / 255, 153.f / 255, 153.f / 255, 1);
glClear(GL_DEPTH_BUFFER_BIT);
glMatrixMode(GL_PROJECTION);
glPushMatrix();
gluPerspective(60, width / height, 0.01f, 10.0f);
glMatrixMode(GL_MODELVIEW);
glPushMatrix();
gluLookAt(0, 0, 0, 0, 0, 1, 0, -1, 0);
glTranslatef(0, 0, +0.5f + app_state.offset_y*0.05f);
glRotated(app_state.pitch, 1, 0, 0);
glRotated(app_state.yaw, 0, 1, 0);
glTranslatef(0, 0, -0.5f);
glPointSize(width / 640);
glEnable(GL_DEPTH_TEST);
glEnable(GL_TEXTURE_2D);
glBindTexture(GL_TEXTURE_2D, app_state.tex.get_gl_handle());
float tex_border_color[] = { 0.8f, 0.8f, 0.8f, 0.8f };
glTexParameterfv(GL_TEXTURE_2D, GL_TEXTURE_BORDER_COLOR, tex_border_color);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, 0x812F); // GL_CLAMP_TO_EDGE
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, 0x812F); // GL_CLAMP_TO_EDGE
glBegin(GL_POINTS);
/* this segment actually prints the pointcloud */
auto vertices = points.get_vertices(); // get vertices
auto tex_coords = points.get_texture_coordinates(); // and texture coordinates
for (int i = 0; i < points.size(); i++)
if (vertices[i].z)
// upload the point and texture coordinates only for points we have depth data for
glVertex3fv(vertices[i]);
glTexCoord2fv(tex_coords[i]);
// OpenGL cleanup
glEnd();
glPopMatrix();
glPopMatrix();
glPopAttrib();
glPushMatrix();
Hello TrayJ,
Thanks for posting in the RealSense community.
The error you are been shown is a bug, I have reproduced it on my end.
I have sent the notification to engineering. Thanks for your feedback.
Juan N.
JTray
Thanks Juan. If they manage to send you a short term fix you might let me know as I would like an example on how best to draw a point cloud
jb455
Valued Contributor II
From the code you pasted [draw_pointcloud(window& app, glfw_state& app_state, rs2::points& points)] it looks like you should be able to pass app instead of app.width() and app.height() - does that work?
JTray
You are correct. I was looking for the complicated solution. I had looked at an older version of the example.cpp file and it was very different to the current version. I thought somehow an older version was uploaded by mistake. Thanks for the help.
