Items with no label
3341 Discussions
Possible bug in capturing: Frame didn't arrive within 5000 / Error occured during execution of the processing block!
pabloalcain
Hello everyone. I have been working lately with the python bindings of the realsense2 library with the D415 model in Linux, and found something that might be a bug (or likely underdocumented error) when accumulating frames.
When I append the outputs from `pipeline.wait_for_frames()` to different python lists, it looks like it blocks the depth or color frame object and after 16 frames of appending it throws an error "Frame didn't arrive within 5000". If we try to align to the color frame, the error is "Error occured during execution of the processing block!".
However, this is easily overcome when appending a copy of said frames, which looks like a good solution and not too costly performance-wise. Before thinking of any PR to the main repo, I wanted to know whether this behavior was expected.
I am yet to understand completely the nature of the bug, but here I leave you the gists that trigger both errors, and the `copy` workaround.
If it helps, I found is not time-related but rather number of frames related, and it also is not dependent (I haven't checked all the range though) on the resolution.
Thank you very much in advance,
Pablo
https://gist.github.com/pabloalcain/65610225deb0ae9335e66e1a6c755c57
MartyG
Could you re-post this information on the RealSense GitHub please? That is the official location for reporting possible bugs with RealSense. This makes it possible for the RealSense developers to track and investigate possible bugs. Thanks!
To create a post on the GitHib, please visit the link below and then click the 'New Issue' button on that page.
https://github.com/IntelRealSense/librealsense/issues
Also, please note that the RealSense forum has moved to a new location, so future questions should be posted there so that the Intel support team can respond. Thanks again!
https://support.intelrealsense.com/hc/en-us/community/topics
pabloalcain
Thanks Marty! I will do that
