Items with no label
3341 Discussions
Problem with Intel Realsense SR 300 camera
SKumb1
I have a SR300 camera and have major problem with it. When an application is activating the camera, the led gives one little blink and the camera disconnects itself. I hear the windows USB-disconnect sound which is followed by the USB connect sound.
Every application I try gives the same result.
install intel_rs_dcm_sr300_3.3.27.5718
intel_rs_sdk_offline_package_10.0.26.0396
I even completely re-installed my PC because I thought it has something to do with a windows update.
Tried every usb3 port. Reinstalled everything a thousand times.
I have attached snaps of this work. Please help me.
MMark14
check out the other post about this problem
MMark14
Hi Shyam_Quadtech,
This thread is very similar to the post that Ipas mentioned: https://communities.intel.com/thread/109177 https://communities.intel.com/thread/109177, the best recommendation that I can give you is to check it.
Have a nice day.
-Leonardo
SKumb1
Hello Sir,
As you mentioned in reply, I send you the information about msinfo32 and sdk_log.
Please find the attachments.
Thank you.
Hi Shyam_Quadtech,
Thank you so much for the information provided, we are going to continue the support of your case on the other thread to avoid confusions. https://communities.intel.com/thread/109177 https://communities.intel.com/thread/109177
Have a nice day.
-Leonardo
SKumb1
Hello Sir,
Thanks for your reply. I am waiting for your valuable response.
