Items with no label
3335 Discussions
Problem with the Realsense SDK 2.0 and OpenCV
ABaye1
Hello
I'm not sure if the problem comes from the Intel Realsense library or from OpenCV:
I have a simple program that just gets a RGB image from the Intel Realsense D435, converts the image to BGR with the OpenCV function cvtColor and shows it with OpenCVs imshow.
This works until I activate the depth camera and the RGB camera of the Intel Realsense D435 at the same time. Then I get some frames where it seems like the conversion of the RGB image was not done by OpenCV. So red appears blue and vice versa. This happens in irregular intervals.
I based the code on the OpenCV imshow example from github.
I'm using the newest OpenCV version 3.4.3 and Intel Realsense SDK 2.0 version 2.16.0.
I also posted this question on answers.opencv.org because I'm not shure if this is a problem with Intel Realsense or OpenCV.
Here is my code:
# include <</span>librealsense2/rs.hpp> // Include RealSense Cross Platform API
# include <</span>opencv2/opencv.hpp> // Include OpenCV API
int main(int argc, char * argv[]) try
// Declare RealSense pipeline, encapsulating the actual device and sensors
rs2::pipeline pipe;
rs2::config cfg;
//depth stream config
cfg.enable_stream(RS2_STREAM_DEPTH, 1280, 720, RS2_FORMAT_Z16, 30);
//colour stream config
cfg.enable_stream(RS2_STREAM_COLOR, 1280, 720, RS2_FORMAT_RGB8, 30);
// Start streaming
pipe.start(cfg);
const auto window_name = "Display Image";
cv::namedWindow(window_name, cv::WINDOW_AUTOSIZE);
while (cv::waitKey(1) <</span> 0 && cvGetWindowHandle(window_name))...
Hello Honk5000,
Thank you for your interest in the Intel RealSense D435 camera.
The problem we have noticed is that the source Mat and the destination Mat are the same
cv::cvtColor(image, image, cv::COLOR_RGB2BGR);
Change the code as below and it will work:
cv::Mat image(cv::Size(w, h), CV_8UC3, (void*)colour.get_data(), cv::Mat::AUTO_STEP);
cv::Mat dst; //added this
//convert from RGB to BGR
cv::cvtColor(image, dst, cv::COLOR_RGB2BGR); //changed destination matrix to dst
// Update the window with new data
imshow(window_name, dst); //show the new destination matrix
Eliza
Hello Honk5000,
Eliza
