Items with no label
3340 Discussions
Problems of r200 driver installation in ubuntu 14.04
lkai2
Hello!
I want to install the driver of r200 on a Jetson tk1 with ubuntu 14.04.
So I found a page introducing how to do it.
The following URL is what I referred:
http://www.jetsonhacks.com/2016/06/20/intel-realsense-camera-installation-nvidia-jetson-tk1/ Intel RealSense Camera Installation - librealsense - NVIDIA Jetson TK1 - JetsonHacks
I noticed that in this article it uses libusb 1.0-0 but I have installed libusb 1.0-9 in my tk1 and it must be remained because other device needs this library.
Some errors occurred when I i was installing libusb 1.0-0 to tk1 since it already has 1.0-9.
So I want to known if the driver of r200 could be installed with libusb 1.0-9?
Should I change something in the code?
Thank you for your help!
Hello Kanelan,
Thanks for contacting Intel customer support.
The procedure to install the R200 driver on the Jetson tk1 using Ubuntu 14.04 is not an Intel validated procedure, therefore we do not have documentation or tests on how to achieve it.
The fact that it is not an Intel validated procedure does not mean it cannot be achieved, it just means that Intel has not validated a procedure to achieve it. It would be recommended for you to contact the Jetson support or the JetsonHacks forum that you referenced in order for them to assist you with the procedure they have validated in the past.
Thanks for your understanding.
Juan N.
