Items with no label
3341 Discussions
Question) How can i get RGB value from each pixel on D435 camera?
mgum1
Hello, i've question.
i want each RGB data in each pixel in one frame by D435.
is there any function to get them?
in depth, depth values are easily gettered by "depth.get_distance(i, j)"
but, how can i get RGB value like that way?
thank you.
MartyG
I wonder if this advice might help:
MartyG
mgum1
thank you! you're the great helper!
Andrew_Carluccio
Hello! I followed the link above and have tried to read up on how that information can lead to accessing RGB values of a pixel at a given coordinate, but am unable to make that jump. How did you implement your solution? Presently, I have a wrapper class of sorts through which I hope to abstract this functionality by wrapping it up in a custom .getRGB() call to the wrapper, but I am stuck on what to do under the hood here.
