Items with no label
3341 Discussions
R200 Depth stream on opencv
NRung1
Hello
I am working with the RealSense R200 camera using Visual Studio(c++) and opencv.
I need to use OpenCV to do image processing so I converted the PXCImage * into cv::Mat.
But, as you can see, the two images are different.
Does anybody can help me?
Demo in realsense:
Result of my code use opencv:
This is my code
void main() {
Mat imageColor;
Mat imageDepth;
// Create a PXCSenseManager instance
PXCSenseManager *sm = PXCSenseManager::CreateInstance();
// Select the color stream
sm->EnableStream(PXCCapture::STREAM_TYPE_COLOR, 640, 480, 30);
sm->EnableStream(PXCCapture::STREAM_TYPE_DEPTH, 320, 240, 30);
// Initialize and Stream Samples
sm->Init();
for (;;) {
// This function blocks until a color sample is ready
if (sm->AcquireFrame(true)
// retrieve the sample
PXCCapture::Sample *sample = sm->QuerySample();
if (sample->color != NULL) {
ConvertPXCImageToOpenCVMat(sample->color, &imageColor);
namedWindow("imageColor", CV_WINDOW_AUTOSIZE);
imshow("imageColor", imageColor);
if (sample->depth != NULL) {
ConvertPXCImageToOpenCVMat(sample->depth, &imageDepth);
imageDepth.convertTo(imageDepth, CV_8U, 255.0 / 4096.0);
namedWindow("imageDepth", CV_WINDOW_AUTOSIZE);
imshow("imageDepth", imageDepth);
if (waitKey(1) >= 0) break;
sm->ReleaseFrame();
// Close down
sm->Release();
//ConvertPXCImageToOpenCVMat From https://stackoverflow.com/questions/37266390/how-to-convert-realsense-rgb-frame-to-cvmat-in-ubuntu-or-other-linux-env
void ConvertPXCImageToOpenCVMat(PXCImage *inImg, Mat *outImg) {
int cvDataType;
int cvDataWidth;
PXCImage::ImageData data;
inImg->AcquireAccess(PXCImage::ACCESS_READ, &data);
PXCImage::ImageInfo imgInfo = inImg->QueryInfo();
switch (data.format) {
/* STREAM_TYPE_COLOR */
case PXCImage::PIXEL_FORMAT_YUY2: /* YUY2 image */
case PXCImage::PIXEL_FORMAT_NV12: /* NV12 image */
throw(0); // Not implemented
case PXCImage::PIXEL_FORMAT_RGB32: /* BGRA layout on a little-endian machine */
cvDataType = CV_8UC4;
cvDataWidth = 4;
break;
case PXCImage::PIXEL_FORMAT_RGB24: /* BGR layout on a little-endian machine */
cvDataType = CV_8UC3;
cvDataWidth = 3;
break;
case PXCImage::PIXEL_FORMAT_Y8: /* 8-Bit Gray Image, or IR 8-bit */
cvDataType = CV_8U;
cvDataWidth = 1;
break;
/* STREAM_TYPE_DEPTH */
case PXCImage::PIXEL_FORMAT_DEPTH: /* 16-bit unsigned integer with precision mm. */
case PXCImage::PIXEL_FORMAT_DEPTH_RAW: /* 16-bit unsigned integer with device specific precision (call device->QueryDepthUnit()) */
cvDataType = CV_16U;//cv16u
cvDataWidth = 2;
break;
case PXCImage::PIXEL_FORMAT_DEPTH_F32: /* 32-bit float-point with precision mm. */
cvDataType = CV_32F;
cvDataWidth = 4;
break;
/* STREAM_TYPE_IR */
case PXCImage::PIXEL_FORMAT_Y16: /* 16-Bit Gray Image */
cvDataWidth = 2;
break;
case PXCImage::PIXEL_FORMAT_Y8_IR_RELATIVE: /* Relative IR Image */
cvDataType = CV_8U;
cvDataWidth = 1;
break;
// suppose that no other planes
if (data.planes[1] != NULL) throw(0); // not implemented
// suppose that no sub pixel padding needed
if (data.pitches[0] % cvDataWidth != 0) throw(0); // not implemented
outImg->create(imgInfo.height, data.pitches[0] / cvDataWidth, cvDataType);
memcpy(outImg->data, data.planes[0], imgInfo.height*imgInfo.width*cvDataWidth * sizeof(pxcBYTE));
inImg->ReleaseAccess(&data);
MartyG
Comparing your script with other PCX to .mat conversions, other people tend to use InputInfo for their size definition instead of your ImgInfo. Examples:
https://stackoverflow.com/questions/37266390/how-to-convert-realsense-rgb-frame-to-cvmat-in-ubuntu-or-other-linux-env opencv - How to convert realsense RGB frame to cv::Mat in ubuntu (or other linux env)? - Stack Overflow
NRung1
Hi MartyG.
Thank you for reply. But my main problem is each pixel in my image when object closer camera it show black but in demo it show white.
Can you help me?
MartyG
My apologies. When you said the two images were "different", I thought you meant the size because of the different size of your two images.
Somebody else had a case where their depth scan was different in OpenCV than in a RealSense demo. They believed it was because the RealSense depth stream was coded in a 16-bit resolution but was only being displayed in 8 bits in the OpenCV image (kind of like converting a 16-bit Nintendo Super NES videogame to the older 8-bit NES).
https://stackoverflow.com/questions/42356562/realsense-opencv-depth-image-too-dark c++ - RealSense OpenCV Depth Image Too Dark - Stack Overflow
Somebody else who had a black bar across their OpenCV image said that they found it occurred because they defined their image by the measurements in the format 'height, width' instead of 'width, height'. "I had my size defined as cv::Size(height, width), instead of cv::Size(width, height). OpenCV's [row, col] format or [col, row] format tricks me up yet again. It works now."
Your own script arranges the measurements as height first and then width, so I wonder if that may be a cause of the difference.
NRung1
I try to change width and height. But it doesn't help.
MartyG
Here's another conversion script for comparison. The script is halfway down the page.
http://giamuhammad.net/installing-intel-realsense-sdk-c-and-opencv-in-visual-studio-2015/ Installing Intel RealSense SDK C++ and OpenCV in Visual Studio 2015 – GiaMuhammad.Net
In their conversion, they use frameDepth in the convertTo instruction instead of imageDepth.
Hello BrokenAngeLa,
I was wondering if you could check the last suggestion provided by MartyG.
If you have any update or question, don't hesitate to contact us.
Andres V.
