Items with no label
3340 Discussions
R200 calibration app error: ds_invalid_arg
hsheh1
Hi, I have the R200 camera and I need to calibrate it. I downloaded the calibrator app, but when I run it, I get the following:
An unexpected error has occurred.
Please try restarting your device and run this application again.
Error: DS_INVALID_ARG
I run it on Lenovo ideapad 700 and the camera works perfectly fine in Linux
I tried restarting and tried re-installing.
I also tried uninstalling Depth Camera Manager as suggested somewhere here in the forum, but then I get the missing DSAPI.dll error
MartyG
This error with the calibrator usually occurs on devices with pen support such as Wacom MobileStudio Pro and Acer Aspire Switch 12. An R200 camera typically does not need to be recalibrated.
If your screen has an obstructive window called the 'Intel RealSense Camera Calibration Notifier' when the device starts up, you can stop it appearing by opening the Windows Task Manager interface with the Ctrl-Alt-Del keyboard shortcut, going to the 'Start-up' option tab on the top of the Task Manager window and seeing if the calibrator app is in the list of apps that are set to automatically appear at start-up. If it is in the list, set its status to 'Disabled' to prevent it from launching on start-up.
Please continue the conversation at the RealSense GitHub site. Thanks!
