Items with no label
3341 Discussions
RL200 module connector
DBier
Hello.
I have RL200 camera. It is use USB 3.0 but RL200 has some of strange socket(in datasheet they call it module connector). Can someone tell me name of that socket or name of plug which i can use to connect my camera with computer??
MartyG
If you are referring to the thin connector that the USB cable plugs into on the side of the camera, that is a USB Type A. I believe that the type of cable used is called Type A To Micro B.
https://www.lifewire.com/what-is-usb-3-0-2626038 What is USB 3.0? (USB 3.0 Definition)
MartyG
The USB connector parts (known as IPEX parts) attach to another connector behind it. It looks as though the picture shows the connector that the USB section plugs onto. The part shown is in Table 7.9 on page 39 of the data sheet.
If you wish to order the IPEX connector parts, you can do so at this page on the IPEX website.
https://www.i-pex.com/Products/detail/83 https://www.i-pex.com/Products/detail/83
If you want to attach the connector in your picture to your computer, I would guess that you need the end connector part to plug onto it so the USB cable can be attached to the camera.
DBier
Unfortunately, I-PEX did not answer about plug.
Is it any other way to buy that plug, i can not find:/
MartyG
I thoroughly researched the part you want but it seems to be extremely hard to find for sale outside of the I-PEX site, and for those who have it, they may not be reliable suppliers. Most refer to the part by its "I-PEX 20346" code-name.
I did find a Hong Kong based seller with a fairly professional site who seems to stock 20346. They refer to the part by the manufacturer Dai-ichi Seiko, who are the parent company of IPEX.
http://www.ipexcable.com/product/dai-ichi-seiko-i-pex-cabline-v/ http://www.ipexcable.com/product/dai-ichi-seiko-i-pex-cabline-v/
Edit: the full part number is I-PEX 20346-20346-010T-31R. The above link has 32R. I don't know how close they are in design, so you might want to email them to ask if they have a 31R so you do not get a wrong-sized part..
