Items with no label
3341 Discussions
Range accuracy of RealSense D415/435
TM6
There seems to be conflicting information about the depth accuracy of D415/D435 sensors:
  1. https://www.intel.com/content/www/us/en/support/articles/000026260/emerging-technologies/intel-realsense-technology.html Depth Resolution of Intel® RealSense™ Depth Camera D435 and Intel®...
    1. Says <1%</li>
  2. https://software.intel.com/sites/default/files/Intel_RealSense_Depth_Cam_D400_Series_Datasheet.pdf https://software.intel.com/sites/default/files/Intel_RealSense_Depth_Cam_D400_Series_Datasheet.pdf
    1. Says < 2%
Which of them is correct? What am I missing?
MartyG
The commonly quoted margin of error value for the 400 Series' depth range is < 1%. In real world terms though, depth accuracy can vary depending on distance and the selected resolution. The greater the distance, the greater the margin of distance measuring error that can be introduced. The key phrase, then, as described by the document you linked to, is "less than one percent of the distance from the object".
TM6
Hi MartyG,
Thank you for your response, but I don't know why the datasheet https://software.intel.com/sites/default/files/Intel_RealSense_Depth_Cam_D400_Series_Datasheet.pdf https://software.intel.com/sites/default/files/Intel_RealSense_Depth_Cam_D400_Series_Datasheet.pdf does not say 1%, when the test set up to measure depth accuracy as described in it, is measuring the distance from the object.
Also - I am looking for information about the distribution of depth measurement error. Is it 0 mean?
MartyG
Maybe you can find something useful in the 'Documents' and 'White Papers' sections of the RealSense downloads page.
https://realsense.intel.com/intel-realsense-downloads/# documents Intel® RealSense™ Downloads, Documents and Tools
