Items with no label
3341 Discussions
RealSense D435 access violation
FKick
I want to use the Intel RealSense D435 for a new project with Qt 5.10.1. I tried to run the example "rs-capture.cpp" (https://github.com/IntelRealSense/librealsense/blob/master/examples/capture/rs-capture.cpp librealsense/rs-capture.cpp at master · IntelRealSense/librealsense · GitHub). The build succeeds, but whenever I execute it, it crashes.
The crash occurs at pipe.start() (line 23) with the error: Exception at 0x7ffa7dd5643a, code: 0xc0000005: read access violation at: 0xffffffffffffffff, flags=0x0 (first chance).
Can anybody please tell me if this is a problem with the hardware, the library etc.? I checked for any missing depencies, but they were all fine.
My setup:
Windows 10 Pro Version 1703
API version 2.15.0
Firmware version 5.10.3
Thank you very much!
MartyG
This Windows access violation (it does not originate with RealSense) apparently has numerous causes, making it hard to diagnose. Memory issues, viruses or a bad Windows registry are among the most common causes. It may also be caused by being unable to locate a file.
https://stackoverflow.com/questions/5303524/what-exactly-is-the-scope-of-access-violation-0xc0000005 windows - What exactly is the scope of Access Violation '0xc0000005'? - Stack Overflow
FKick
Thank you for your answer.
After some time I solved the problem, it had nothing to do with the RealSense SDK at all.
MartyG
Awesome news, thanks for letting us know. Have a great day!
