Items with no label
3340 Discussions
RealSense D435 with jetson TX2 : depth stop working/freezes after time
QBoul1
Hi guys!
I use a RealSense D435 with my Jetson TX2. After working perfectly, the depth always stop working/ freezes after time. No problem with the RGB.
My code run at around 13fps; and I set the pipeline to 60 fps. I thought this was the problem. So I tried setting the camera at 6fps. This result indeed in my code running at 6fps. But still the same problem... even though, it comes later ( after 5min, sometimes, 10min, compared to 1min - 2 min).
The guy that will solve this claim is brilliant! I'm lost...
Here is my code:
[code]
# Libraries imports
import pyrealsense2 as rs # for realsense camera
import numpy as np
import cv2 as cv
import time # needded to calculate FPS
class Camera:
  Class that contains basic Camera management functions without using threading
  def __init__(self, src=0):
    # Create a pipeline
    self.pipeline = rs.pipeline()
    # Create a config and configure the pipeline to stream
    # different resolutions of color and depth streams
    self.config = rs.config()
    self.config.enable_stream(rs.stream.depth, 640, 360, rs.format.z16,
                 60) # other possible valus for the fps are 6, 15,...
    self.config.enable_stream(rs.stream.color, 640, 480, rs.format.bgr8,
    # Start streaming
    self.profile = self.pipeline.start(self.config)
    # Getting the depth sensor's depth scale:
    self.depth_sensor = self.profile.get_device().first_depth_sensor()
    self.depth_scale = self.depth_sensor.get_depth_scale()
    print("Depth Scale is: ", self.depth_scale)
    # Create an align object
    # rs.align allows us to perform alignment of depth frames to others frames
    # The "align_to" is the stream type to which we plan to align depth frames.
    self.align_to = rs.stream.color
    self.align = rs.align(self.align_to)
  def grab(self):
    # Get frameset of color and depth
    frames = self.pipeline.wait_for_frames()
    # frames.get_depth_frame() is a 640x360 depth image
    # Align the depth frame to color frame
    aligned_frames = self.align.process(frames)
    # Get aligned frames
    aligned_depth_frame = aligned_frames.get_depth_frame() # aligned_depth_frame is a 640x480 depth image
    color_frame = aligned_frames.get_color_frame()
    # Create the array that will countains the frame.
    # Channels will be: BGRD
    image = np.ones((480, 640, 4))
    image[:, :, :3] = np.asanyarray(color_frame.get_data()) # Store the BGR image in the array image
    image[:, :, 3] = np.asanyarray(
      aligned_depth_frame.get_data()) * self.depth_scale # store the depth (in meters) in the fourth channels
    return image
  def read(self): # used for an easy conversion from the CameraThreading class to this one
    return self.grab()
  def readRGB(self, image): # Isolate the BGR canals and put it in the right format for it to be understood by openCV
    return image[:, :, :3].astype(np.uint8)
  def showDepthGreen(self, image):
    depth = np.ones((480, 640, 3))
    depth[:, :, 1] = image[:, :, 3] * 100
    return depth.astype(np.uint8)
  def stop(self): # Close pipeline
    self.pipeline.stop()
# If run of the file, test the frame grabbing and calculate performance
if __name__ == "__main__":
  camera = Camera(0)
  time.sleep(1)
  while (cv.waitKey(1) & 0xff != ord('q')): # Loop as q is not pressed
    start = time.time() # start clock measurer
    image = camera.grab() # grab An Image
    cv.imshow("frames", camera.readRGB(image)) # Show the RGB image
    cv.imshow("depth", camera.showDepthGreen(image)) # Show the RGB image
    # Write performances:
    print("Took: " + str(time.time() - start) + " s")
    print('FPS: ' + str(1 / (time.time() - start)))
  # Once q is pressed, close the camera and destroy the windows:
  camera.stop()
  cv.destroyAllWindows()
[/code]
Thank you!!
Quentin
MartyG
The symptoms are suggestive of a 'memory leak' in the program, where the computer memory gets consumed over time until the program stops working. The higher the FPS, the faster the memory would be consumed.
One cause of a leak may be frames not being properly "released" at the end of a script.
If you monitor your PC's current available memory whilst the program is running then this will show if the memory is running down abnormally fast.
You could also check whether the CPU is running at a high load such as 100% usage, which would be another cause of slowness and instability.
