Items with no label
3341 Discussions
RealSense SDK 2.0 version 2.17.0 now available (API updates)
MartyG
Hi everyone,
Version 2.17.0 of the RealSense SDK 2.0 is now available for download from the link below.
https://github.com/IntelRealSense/librealsense/releases/ Releases · IntelRealSense/librealsense · GitHub
API CHANGES
This new version introduces numerous updates to the API of the SDK, including:
- Changes to rs2_pipeline_start_with_callback
- New API to control recording compression
- Support for IMU stream and recording IMU frames in software sensor
- Support for pose stream and recording pose frames in software sensor
- API to generate IMU and pose data with software_device
- Create recorder and explicitly enable or disable compression
- C++ processing_block class is split into processing_block and filter classes
Full details of the changes to the API can be found here:
https://github.com/IntelRealSense/librealsense/wiki/API-Changes# from-2160-to-2170 API Changes · IntelRealSense/librealsense Wiki · GitHub
NEW FEATURES AND IMPROVEMENTS
- Adding rs-callback example for asynchronous (low-latency) processing with pipeline.
- Adding new python and Matlab for point-cloud data visualization
The MATLAB point cloud example can be found here:
https://github.com/IntelRealSense/librealsense/blob/development/wrappers/matlab/pointcloud_example.m librealsense/pointcloud_example.m at development · IntelRealSense/librealsense · GitHub
The Python point cloud renderer example can be found here:
https://github.com/IntelRealSense/librealsense/blob/development/wrappers/python/examples/pyglet_pointcloud_viewer.py librealsense/pyglet_pointcloud_viewer.py at development · IntelRealSense/librealsense · GitHub
- D435i IMU is now supported on Windows 10
- rs-capture will now show IMU data when connected to D435i, and rest of the SDK demos will work properly.
BUG FIXES
- SDK can now be compiled with -Werror=shadow GCC flag
- Fixing symbols collision with ROS libraries
The full release notes, containing all resource links and a list of unresolved Known Issues, can be viewed here:
https://github.com/IntelRealSense/librealsense/wiki/Release-Notes# release-2170 Release Notes · IntelRealSense/librealsense Wiki · GitHub
