Items with no label
3341 Discussions
RealSense SDK version 2.19.2 now available
MartyG
Hi everyone,
Version 2.19.2 of the RealSense SDK is now available for download from the link below.
https://github.com/IntelRealSense/librealsense/releases/
NEW FEATURES AND IMPROVEMENTS
General
  • SDK Examples Enhancements
  • Use CASE macro consistently - contributed by @nussetorten
  • Improved comment on the post processing example contributed by @Heidelberger
  • Fix typo in raspbian installation - contributed by yuta-imai
  • rs-enumerate-devices enhancements
  • Wheel odometry API: use translational velocity
  • Adding CMake option to generate python documentation
  • Add arguments for python threshold filter, contributed by @codinglife001
Android
  • Adding device query and firmware version checking
T265
  • Separate wheel-odometry tests
  • Enforce stream index for fisheye streams of the T265
  • Adding Trajectory example
  • Get Motion Intrinsics
  • Don't raise a hardware event for relocalizations
  • Use T265 system timestamps
Linux
  • Adding minor version to the SONAME #3449 contributed by @morxa
BUG FIXES
  • [D435i][python] IMU FPS can't be changed in Python
  • [Matlab] Aligning colour to depth
  • [Viewer] Fixing SegFault on pose stream info
  • Backward compatibility break for older ROS-bag recordings
  • [T265] Fix query_devices issue with the tracking camera
  • Fixing USB2 being identified as USB3 in some cases
  • Trimming HID timestamps to 32-bit
Full release notes, with all linkages and list of unresolved Known Issues, can be read here:
https://github.com/IntelRealSense/librealsense/wiki/Release-Notes#release-2192
