Items with no label
3341 Discussions
Realsense D435 Matlab wrapper
AFiel1
I am using the new MATLAB wrapper for streaming depth frames from the RealSense D435, essentially using the example script. I am wondering how one changes acquisition parameters from within the MATLAB script e.g. frame rate. This is more of a syntax question really about the arguments for the enable_stream() function. From the config.m script I know that there can be between 2 to 7 arguments including the stream required e.g. depth, infrared or rgb, the format e.g. z16, height and width, and frame rate?
cfg = realsense.config();
%Parameters
nframes=100; % number of frames
height = 480;
width = 640;
% Enable stream(s) and set parameters, height, width, and framerate
cfg.enable_stream();
