Items with no label
3341 Discussions
Realsense D435i - not properly recognized by Realsense-Viewer.
RPerr6
I recently got a Realsense D435i that I updated to the latest firmware available. It was working well until it suddenly stopped being recognized by Realsense-Viewer. When connecting it, the error :
Invalid Value in rs2_get_option_range(options:0x2aaf4e0, option:Depth Units, min:-514102, max:3.92364e-44, step:0, def:7.52112e-38):
hwmon command 0x2c failed. Error type: No expected user action (-9).
It is impossible to stream any data from it, the camera becomes unusable. The serial number is not even retrieved.
I tried to downgrade the firmware, it didn't work. Result is the same on 3 different computers with different USB-C cables.
Any suggestions to fix this issue ?
Rodolphe
MartyG
Please download and install the camera calibration API software using the link below. The API is the lower of two links in the side-panel of the page in this link.
https://downloadcenter.intel.com/download/28517/Intel-RealSense-D400-Series-Calibration-Tools-and-API?v=t
Once the calibration API tool is installed, you can use a program called CustomRW that is part of this tool to 'gold reset' the camera to factory default with the command below:
Intel.Realsense.CustomRW.exe -g
MartyG
