Items with no label
3341 Discussions
Realsense R200 freezes with NVIDIA Tegra K1
JO_o
When we plug the Realsense R200 in to our TK1, running the "r200_nodelet_default" node, it freezes the TK1, does not show any further messages, and does not show any errors after this message:
[ INFO] [1474748112.582733021]: /camera - Starting camera
We have to always press the Reset button on the TK1 after this happens.
Any idea why the Realsense freezes the node/TK1?
Here's what we've tried:
  • To make sure Realsense gets enough power, we plugged it in to a USB hub, which has its own power adapter.
  • To make sure it's not a USB speed issue, we disconnected all other things to the USB hub, which is USB 3.0
  • We have the Grinch kernel installed on the TK1.
  • To make sure it's not an HDMI issue, we removed the cable and are SSHing into the TK1.
  • Power draw is ~10-15% before running ROS, and ~20% running ROS and the node, regardless of whether the camera is plugged in.
Update: Running "r200_nodelet_rgbd.launch" with the Realsense plugged in makes all cores go to 100% and freezing.
I have forwarded this information to the appropriate team. I will update this thread as soon as news become available.
Allan.
Hello Mr. Roboroborobo,
The R200 camera is only validated to run on Intel processors. Please connect your camera to a supported system such as one with a 6th Gen Intel Core Processor running Windows 10, or if you prefer Linux or Android, a system with Atom Z8000 series processor, and see if it works for you.
Running the R200 on an Nvidia system will lead to indeterminate results.
Jesus Garcia
Intel Customer Support
