Items with no label
3341 討論
Reset ROS_MASTER_URI from the CLI
員工
4,086 檢視
I tried to change the ROS_MASTER_URI value via the web app to http://ros:11311/ http://ros:11311/
but apparently the web app scrambled the value. When I run sudo service oobe-init restart-oobe
it complains that the ROS_MASTER_URI value is invalid: http://http://ros:11311:11311/
I did not enter the scrambled value.
So now the web app is wedged. How can I reset ROS_MASTER_URI from the CLI?
Paul
0 積分
1 解決方案
Majd_S_Intel
員工
2,977 檢視
You can go to /intel/euclid/config/settings.ini, there you can change the ROS_MASTER_URI.
Make sure you restart the oobe-init service, as you mentioned after doing so.
We'll check why it is "scrambled" when you use the web as well.
Best,
Majd (Intel)
在原始文章中檢視解決方案
4 回應
Majd_S_Intel
員工
2,978 檢視
Best,
Majd (Intel)
員工
2,977 檢視
Thanks! That did the trick.
MartyG
榮譽貢獻者 III
2,977 檢視
Glad that majdS' answer was able to help - thanks majdS! It was a more useful answer than mine.
MartyG
榮譽貢獻者 III
2,977 檢視
The site below describes a method for changing ros_master_uri on boot-up of your PC (someone claimed the master URL cannot be changed once ROS is running).
http://answers.ros.org/question/35603/ros_master_uri-change-it-and-save-it/ ros_master_uri - change it and save it - ROS Answers: Open Source Q&A Forum
回覆
