Items with no label
3341 Discussions
Restore Euclid / download software
JHemm1
Where can I find download the software that's on my Euclid ?
Is there a tutorial on how to flash it / restore it to factory condition if I mess up some of the original files?
Best,
Jeremy
Tsahi_M_Intel
Hi Jeremy,
You can download Euclid image from our repository at following https://tinyurl.com/y9wb43me link
also would like to note that we have published Euclid code base in https://github.com/inteleuclid GitHub
if you like you can use http://www.euclidcommunity.intel.com/ Euclid Community portal for future updates and samples.
Hope this helps.
Tsahi.
Intel Euclid Development Team
MartyG
Somebody else asked about factory resetting Euclid yesterday. Intel employee Amit Moran - amitmoran - who I believe is from the Euclid team, said that an image would be published soon.
Tsahi_M_Intel
Hi Jeremy,
Hope this helps.
Tsahi.
JHemm1
It helps a lot, thanks Tsahi!
What's the process to flash the image on the device?
MPall2
What is the procedure to this iso to Euclid. I have downloaded and dd-ed into a USB drive. When booted with the jump-drive plugged in in just gets mounted. Can someone please answer this ?.
Thank you !.
MPer
HSalm
Hi MPer,
Did you figure it out? I was to resintall the iso image, but for some reason it is not working. Does anyone tried restoring the Euclid to factory setting s an it actually worked??
MPall2
Yes. Connect a powered usb hub to the type A usb port and attach a mouse, keyboard and a jump drive with the factory default image. The jump drive should installed with a uefi imager like rufus. Simply dd-ing won't work. The at boot time get into the bootloader by pressing F5 or ESC and change the boot priority. The usb jump drive should be connected for it to appear in the boot menu.
