Items with no label
3340 Discussions
Rs400 Visual Presets - how to use
SChop3
I'm trying to alter the depth control parameters of the R435 camera using the visual presets. I've found a way to load presets from a Json file in advanced mode: https://github.com/IntelRealSense/librealsense/blob/master/doc/rs400/rs400_advanced_mode.md https://github.com/IntelRealSense/librealsense/blob/master/doc/rs400/rs400_advanced_mode.md.
However, the .Net wrapper (I'm using .Net) has a type Rs400VisualPresets which contains all of the presets found in the viewer.
The Json approach seems a little involved, is there a simpler method which uses the enums in the wrapper?
jb455
Valued Contributor II
Yep, you can use one of the presets like so:
PipelineProfile profile = pipeline.Start(cfg);
var depthSensor = profile.Device.QuerySensors()[0];
if (depthSensor.Options[Option.VisualPreset].Supported)
depthSensor.Options[Option.VisualPreset].Value = Rs400VisualPreset.HighDensity;
I think that the list of presets might not be finalised though; I read in the comments of one of the samples that they might change. Keep an eye on it when new versions come out!
MartyG
The Visual Presets guide says that as an alternative to using a JSON file, "the user can also modify the settings via the Advanced Mode menu and save a customized user preset."
https://github.com/IntelRealSense/librealsense/wiki/D400-Series-Visual-Presets D400 Series Visual Presets · IntelRealSense/librealsense Wiki · GitHub
jb455
SChop3
Great stuff,
This works great thanks, only one very minor change to the code in case someone else wants to use it.
The Enum needs casting to a float as below.
depthSensor.Options[Option.VisualPreset].Value = (float)Rs400VisualPreset.HighDensity;
