Items with no label
3340 Discussions
SDK examples not working on Up Board (Robotic Kit) with Windows 10
AndreCarlucci
I installed Windows 10, the RealSense SDK, DCM, it installs just fine.
But no SDK example works...
Any thoughts?
Hi Andrecarlucci,
Thanks for contacting us!
We appreciate all the information provided. We would like to let you know that according to the release notes of the SDK and DCM, Intel® Core™ processors are required, and the Up Board has Atom, so this is an unsupported configuration. Moreover, we'd suggest to use librealsense since it is supported as you already know.
Our apologies for any inconvenience it may cause.
-Yermi A.
AndreCarlucci
I tried a small program that just create the session and the manager to start looping through frames.
When I try to enable any module, I get the PXCM_STATUS_ITEM_UNAVAILABLE
The camera appears on the Device Manager (Depth, RGB and the Virtual Driver).
I tried an example with librealsense and it works juts fine.
Could anyone run the RealSense SDK on Windows 10?
Hi Andrecarlucci,
-Yermi A.
