Items with no label
3340 Discussions
SDK for 3-D reconstruction of objects
PP6
I'm using an Intel RealSense 415d with Intel's librealsense SDK Python Wrapper.
I was wondering if you had any modules for automatic 3-D reconstruction of objects. I am looking to align depth frames that have been obtained from multiple viewpoints to generate one ply file for a complete 360-degree view of the object (something on the lines of photogrammetry). If you don't, I would appreciate it if you could point me to some other existing modules that can help me achieve my final objective.
MartyG
Intel did something similar with four hardware-synced D435s at their tech shack at the Sundance Festival in January 2018. The technique is called Volumetric Capture. With 4 cameras they could capture 180 degrees. In their article about the demo, they suggested using 8 or more cameras for a 360 degree capture, adding more cameras until all the holes in the data were filled.
https://realsense.intel.com/intel-realsense-volumetric-capture/ Volumetric Capture @ Sundance using Intel RealSense Depth Cameras
A company called Jaunt also recently introduced a six-camera 360 degree volumetric capture method that seems to use D415s.
You can read Intel's white paper on multi-camera setups and hardware syncing at the link below:
https://realsense.intel.com/wp-content/uploads/sites/63/Multiple_Camera_WhitePaper_rev1.1.pdf https://realsense.intel.com/wp-content/uploads/sites/63/Multiple_Camera_WhitePaper_rev1.1.pdf
MartyG
