Items with no label
3341 Discussions
Saving a PointCloud generated using ZR300 camera
TNasi1
Hi everyone,
Is there a way to save the point cloud generated using a ZR300 camera as .ply format or any other suitable format that can be converted to .ply format later on?
I want to achieve this without using the PCL (point cloud library).I know it can be achieved by using the realsense-viewer that comes with librealsense but the viewer doesn't seem to work with zr300 cameras.
Hello Tasie,
Thanks for contacting Intel customer support.
I have been checking the records and Intel has not validated a method to save the PointCloud generated using the ZR300 without using the PCL. This does not mean that what you are trying to achieve is not possible, this means that Intel does not have any guidelines to achieve it in the way you are trying to.
Juan N.
