Items with no label
3341 Discussions
Schematic for RealSense interposer?
rtsen3
When you remove the case of the R200 you find a small metal enclosure holding the cameras. Nine conductors connect the cameras to an interposer board that expands the connection to a Micro USB 3 B socket. I would like the schematic and BOM of the interposer including the name of the connector and socket. If no one can provide a schematic and BOM, I would also appreciate the name of the pictured connector and socket. Thanks for any help!
ABulz
Hi rtsengMIT,
The cable and connector are 10-pin LVDS like the ones from I-PEX. I would appreciate the schematic too, particularly for the SR300. The R200 and SR300 have different interposers.
Good luck!
Adrian
rtsen3
Thanks! Can you send me a link to the part? I couldn't find it on the I-PEX website.
We may reverse engineer the schematic - it's not very complex. Hopefully someone responds, but if not I'll send it to you if we do it... Thanks!
/Ryan
ABulz
I'm fairly sure it's 20347-310E-12R for the smt cable receptacle, but someone should double check. This is the source page: https://www.i-pex.com/Products/detail/83# ! https://www.i-pex.com/Products/detail/83# !
Hi RtsengMIT,
Thanks, Bulzacki for the help on this; at this point I would recommend you to post on our Intel® RealSense™ Technology Forum, to get further assistance.
Intel® Developer Zone Forum, Intel® RealSense™ Technology
https://software.intel.com/en-us/forums/realsense https://software.intel.com/en-us/forums/realsense
Hellen.
