Items with no label
3341 Discussions
SenseManager.Close() blocking in C# application
PBarc1
I am having an issue with stopping the streams of an SR300 from a C# app. Streams are configured via the SenseManager and started using senseManager.StreamFrames(false); where the false indicated non-blocking mode. This works fine and frames stream correctly. To stop streaming, the documentation states Close() can be called at any time. However, calls to senseManager.Close(); never seem to return.
This issue seems almost exactly the same https://software.intel.com/en-us/forums/realsense/topic/611087 C# - SenseManager.StreamFrames(false) is not stopped by SenseManager.Close() . In that thread the author had a workaround using the blocking version of StreamFrames(true) started in a separate thread, however, this doesn't seem to help in my case.
Most of the c# sample apps dont seem to issue a Close() call, they just leave everything streaming until shutdown.
Any ideas?
Installed:
intel_rs_sdk_mw_core_offline_11.0.27.1384.exe
intel_rs_dcm_sr300_3.3.27.5718.exe
Hi phiip-barclay,
Thank you for contacting us, we'll try to help you solve this situation. I read the thread you linked and the problem is indeed very similar. My first suggestion was going to be to check the functions names of C# and C++, cause in some cases, they differ from one another.
Also, which SDK are you using? The latest SDK release is SDK 2016 R3. In the link you posted, the issue was related to the SDK R2. We want to know if this issue persists on SDK R3 as well.
We'll be waiting on your response so we can have more information and see if we can help you out or if we should classify this as a bug.
-Sergio
PBarc1
Thanks for the response.
The C# call to Close() is as per the documentation here: https://software.intel.com/sites/landingpage/realsense/camera-sdk/v2016r3/documentation/html/index.html?doc_essential_streaming_through_pxcmsenseman.html Intel® RealSense™ SDK 2016 R3 Documentation
Version info:
SDK 2016 R3 (11.0.27.1384)
DCM SR300 (3.3.27.5718)
Main code chunks:
using RS = Intel.RealSense;
private RS.Status InitCamera()
RS.Status initStatus;
try
senseManager = RS.SenseManager.CreateInstance();
RS.SampleReader readerRGB = RS.SampleReader.Activate(senseManager);
readerRGB.EnableStream(Intel.RealSense.StreamType.STREAM_TYPE_COLOR, 640, 480, 30);
readerRGB.SampleArrived += OnNewSample;
RS.SampleReader readerDepth = RS.SampleReader.Activate(senseManager);
readerDepth.EnableStream(Intel.RealSense.StreamType.STREAM_TYPE_DEPTH, 640, 480, 30);
readerDepth.SampleArrived += OnNewSample;
initStatus = senseManager.Init();
catch (Exception e)
throw new Exception("Failed to initialize RSStreamingRGB : " + e.Message);
return initStatus;
public void StartStreaming()
if (!initialized)
InitCamera();
// Either of these cause .Close() to block
//Task.Factory.StartNew(() => { senseManager.StreamFrames(true); });
public void StopStreaming()
private void OnNewSample(object sender, RS.SampleArrivedEventArgs args)
// Do some stuff with the fresh samples
Thank you for providing the information we requested. We'll do some research to try to find more information about this. We'll contact you as soon as we have an update.
-Sergio
Thank you for waiting. After doing some tests, we were unable to reproduce the issue of the application hanging because sensemanager.Close() did not return.
To test this, I opened %RSSDK%/sample/core/RawStreams.cs/RawStreams.cs_vs2012_15.sln and navigated to raw_streams.cs file. In line 151 in the function StreamColorDepth() there is the line sm.Dispose();. When I add sm.Close() before Dispose it works fine. The application returns from Close and continues to Dispose.
You can also try using sensemanager.Dispose() without using Close() and see if that is acceptable.
Let us know your results.
-Sergio
Hi phiip-barclay,
We were wondering if you had a chance to look at our previous suggestion. Please let us know if you still need assistance with this case.
-Sergio
