Items with no label
3341 Discussions
Steps for using QueryVertices()
Hi, i´m not sure of how to use QueryVertices properly.
Could someone clarify me the steps to do a correct use of the function QueryVertices()?
Thanks!
Hi Migueel,
Thank you for contacting us.
To use the QueryVertices() function, I recommend you to check the SDK R3 documentation, you can learn how to use it: https://software.intel.com/sites/landingpage/realsense/camera-sdk/v2016r3/documentation/html/index.html?queryvertices_pxcprojection.html
I also found the Projection Sample ( https://software.intel.com/sites/landingpage/realsense/camera-sdk/v2016r3/documentation/html/index.html?sample_projection_cpp.html), in that sample the function QueryVertices is used, you can take a look at it and use the sample as a reference for your own code.
I hope you find this helpful.
Leonardo R.
Hi Migueel,
Leonardo R.
