Items with no label
3341 Discussions
There is a warning when using Intel® Driver & Support Assistant to update the Intel GPU driver
cw_intel
When using Intel® Driver & Support Assistant to update the Intel GPU driver, a warning will appear, as shown in the picture below. It shows the encouragement to use OEM drivers and ‘use for testing only’ warning.
And from this warning, can get the below information,
 1. Intel website says you should NOT use their drivers for anything other than testing – and refers to ACER website, which has an OLDER driver than Microsoft.
2. After Intel website says to NOT use their drivers for anything other than testing, Intel website has scary license terms aimed to dissuade use of pre-release software?
Why shows this warning? Could it be fixed?
