Items with no label
3340 Discussions
Transceiver for active HW synchronization
TJan
I read the whitepaper on the use of multiple cameras and ways to synchronize them. I need to use 4-6 D435 with 5-6m between them. In the whitepaper you recommend using a RS-485/RS-422 transceiver and ethernet patches. Do you have a reference for some pre-made transceivers ?
Thank you.
MartyG
Since Intel recommends Digikey as the purchasing source for the cable connector parts, it would be logical to get the RS-485\RS-422 from Digikey too.
https://www.digikey.com/catalog/en/search?filters=17645 Search results | Online Catalog | DigiKey Electronics
TJan
I will rephrase a bit. I know RS-485\RS-422 transceiver can be bought. I saw a bunch of small boards with the RO/RE_/DE/DI/vcc/gcc pins and ethernet plug. Those have to be ordered from china with more than a month for shipping.
I would like to know if some people already tried such boards and if they can recommend some with US/Canada resellers to avoid having to buy everything separately and the hassle of dealing with sdm.
