Items with no label
3341 Discussions
Two RealSense API questions
OMora2
  1. We are using RealSense SDK 2.17.0 on both Windows and Ubuntu platforms, and we see different that the supported rs2_frame_metadata_value on the two platforms are not identical, even when using the same sensor and firmware. Namely, RS2_FRAME_METADATA_FRAME_COUNTER and RS2_FRAME_METADATA_SENSOR_TIMESTAMP are supported on Windows and not supported on Linux. Is this a bug, limitation or are we doing something wrong? Will this gap be closed in the near time?
  2. When calling rs2::frame::get_data(), a void* buffer is returned. Who is responsible for de-allocating this buffer, and is it 'valid' as long as the rs2::frame object is valid, or is it being re-used at some time for a new frame?
Thanks in advance!
MartyG
The metadata documentation can assist with your first question regarding Linux / Windows metadata, in a section headed '​OS support'.
https://github.com/IntelRealSense/librealsense/blob/master/doc/frame_metadata.md#os-support
MartyG
