Items with no label
3340 Discussions
Unable to Disable RS2_STREAM_INFRARED
vhanded
Hi, I am using D410 module (variant without color). I called
conf.disable_stream(RS2_STREAM_INFRARED); enable_stream(RS2_STREAM_DEPTH);
However, when I call:
poll_for_frames(frameset);
I got 2 frames in each frameset (depth + infrared).
Is Infrared stream always enable, when depth stream is enabled?
vhanded
Thanks @MartyG​ , I had found the reason.
Even after I disabled all the streams, and only enable depth stream, but whenever I requested any data that requires color/infrared, the stream will be activated automatically.
rs2::pipeline pipe; rs2::config c; c.disable_all_streams(); c.enable_stream(RS2_STREAM_DEPTH, RS2_FORMAT_Z16, 30); pipe.start(c); rs2::frameset data = pipe.wait_for_frames(); cout << data.size() << endl;
The above code will show only 1.
rs2::colorizer color_map; rs2::pipeline pipe; rs2::config c; c.disable_all_streams(); c.enable_stream(RS2_STREAM_DEPTH, RS2_FORMAT_Z16, 30); pipe.start(c); rs2::frameset data = pipe.wait_for_frames().apply_filter(color_map); cout << data.size() << endl;
The above will show 2.
MartyG
You could try disabling the left and right IR streams individually by index number in the same way that they can be activated individually.
conf.disable_stream(RS2_STREAM_INFRARED, 0);
conf.disable_stream(RS2_STREAM_INFRARED, 1);
I notice that you have not put the config instruction in front of your depth line. If you are setting the depth stream up, it should usually be expressed as:
conf. enable_stream(RS2_STREAM_DEPTH);
vhanded
