Items with no label
3341 Discussions
Using rs2::config in RS2
MAbdo2
I wish to configure the RealSense device, and then save the configuration into a file. Then, at a later time, I would like to use this configuration file to start the pipe. My understanding is that I can load the configuration file using config.enable_device_from_file. Am I on the right path? If not, please suggest the correct way of doing this.
Mo
MartyG
You can use the Advanced Mode controls in the RealSense Viewer software to create a customized 'Visual Preset' for future use.
https://github.com/IntelRealSense/librealsense/wiki/D400-Series-Visual-Presets D400 Series Visual Presets · IntelRealSense/librealsense Wiki · GitHub
If you need to do this in scripting, the page linked to below shows how to write the Advanced Mode values to a file called a JSON and then load the data back in.
https://github.com/IntelRealSense/librealsense/blob/master/doc/rs400/rs400_advanced_mode.md librealsense/rs400_advanced_mode.md at master · IntelRealSense/librealsense · GitHub
