Items with no label
3341 Discussions
What is the Best and Newer version of RealSense camera available in the market - SR300 ??
ILoza
Hello I want to buy a RealSense Camera and I found different models available ZR300 F200 R200 and SR300, plus dev kits (https://www.newegg.com/Product/Product.aspx?Item=1EF-007J-00001 REALSENSE DEVELOPMENT KIT-Newegg.com )
what is the best and newer recommendation ?
So far I found this two different versions for SR300 on Mouser Electronics http://www.mouser.com/Search/ProductDetail.aspx?qs=33AqgSIO4a6GrmoNr1kb8w%3d%3d 82535IVCHVM and http://www.mouser.com/Search/ProductDetail.aspx?qs=33AqgSIO4a7rRjAEvPCh3Q%3d%3d 82535IVCQSPL04N
http://www.mouser.com/Search/ProductDetail.aspx?qs=33AqgSIO4a6GrmoNr1kb8w%3d%3d http://www.mouser.com/Search/ProductDetail.aspx?qs=33AqgSIO4a6GrmoNr1kb8w%3d%3d (Video Modules Intel RealSense Camera SR300)($75.00)
http://www.mouser.com/Search/ProductDetail.aspx?qs=33AqgSIO4a7rRjAEvPCh3Q%3d%3d http://www.mouser.com/Search/ProductDetail.aspx?qs=33AqgSIO4a7rRjAEvPCh3Q%3d%3d (Video IC Development Tools Intel RealSense Development Kit Featuring the SR300)($149.00)
I can find from this last two, both are different versions for the SR300 and the cameras looks different and have double price
I will appreciate if somebody can help me to decide which is better, newer and if you can recommend a provider to deliver fast in SF area I will appreciate too =)
Thank you, you are the best guys!!!
Ivan
MartyG
The camera you choose will depend on the kind of projects you want to create. The SR300 is suited to indoor applications, whilst the R200 and ZR300 can be used both indoors and outdoors.
Other factors that may influence your decision are that support for the R200 has ended in the Realsense SDK software, and the ZR300 does not have SDK support in Windows yet, using Linux instead.
If you are considering the SR300 you should pick the 149 one, as the 75 one seems to be just for the camera's internal circuit board
If you choose a Developer Kit camera, you should order it from Intel's official online store. If buying a caseless circuit board version of the camera, I highly recommend ordering from an approved Intel distributor such as Mouser please.
MartyG
ILoza
Heeey! MartyGthanks for your help!
OK so I will order this one from intel's sotre https://click.intel.com/intelrealsense-developer-kit-featuring-sr300.html Intel® RealSense™ Developer Kit (SR300) - Intel® RealSense™ Developer Kits
I see that intel have 2-3 days delivery =) yeeeey
I appreciate your help Marty, you are the best!
MartyG
Glad I could help to inform your decisions. . Good luck and please visit the forum any time!
