Items with no label
3341 Discussions
What is the minimal set of firmware files I need to use NUC
mBeha
So today I learned that my GNU/Linux distribution's `linux-unfree-firmware` package is 491 Mb in size. I'm pretty sure my Intel NUC hardware doesn't need all of these files. Hence I think I can reduce this disk usage if I'll only know what files I can exclude from there.
Is there any official documentation, that states exactly what files from https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ are needed specifically for Intel NUC5i7RYH ?
AlHill
Linux is not supported on your NUC:
https://www.intel.com/content/www/us/en/support/articles/000005628/intel-nuc.html
Using Windows, you can see all of the downloads for your nuc here:
https://downloadcenter.intel.com/product/87570/intel-nuc-kit-nuc5i7ryh
You need to contact your linux vendor.
https://www.intel.com/content/www/us/en/support/topics/linux-osv.html
Doc
Konstantin
You should stop post this for every Linux problem.
AlHill
maybe, but it is the correct response. Just check the links - they are Intel's documents, not mine.
And, you should read the forum header:
"Find and share solutions with Intel users across the world
This is a community forum where members can ask and answer questions about Intel products."
You see, I am a customer like you. If you have a better, correct answer, then provide the answer.
Doc
Konstantin
There is big difference between OFFICIALLY not supported and not works. You really think that people drop Linux and install Windows instead? For Linux user answer like "Linux is not supported, install Windows instead" is worse than no answer.
AlHill
I never said to install windows. You did.
I do not need to debate such a stupid issue. That you do says something.
Doc
Konstantin
Come on, but why you write about windows in question about linux?
Issue is not stupid, only your answers.
mBeha
For the record, I'll testify that my WiFi doesn't work if I don't install this firmware. More over, the Git repository I linked in my question (https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/) is a repository of firmware files that come in the form of binary blobs and they are all maintained by hardware makers such as Intel. So, since my hardware works thanks to the existence of this files which are given to me almost directly by Intel, I assume that means my hardware is Linux supported.
As for your comment @[Al.Hill] saying I should contact my Linux Distro, that's certainly a rather (stupid) unhelpful answer, as usually Linux distros are managed by the community and if I don't know such an answer, it's likely no one in my community will know..
@[Al.Hill] you are making the impression you don't really know even the basic things there are to know about GNU/Linux ecosystems, hence I think what's annoying in your responses, are that you are trying to show knowledge you don't posses. And that annoys me too as a 1st time writer in this forum.
n_scott_pearson
Al is correct; we cannot provide this kind of information here. For more information, see https://www.intel.com/content/www/us/en/support/articles/000005499/intel-nuc.html.
