Items with no label
3340 Discussions
Where can I find the camera calibration file for Realsense T265?
RNagy
Hi All,
I'm using the Intel Realsense T265 in OpenCV and Python environment. I can see the video stream from the stereo fisheye cameras and the position of it, so the setup worked well with the product. My problem is, I would like to include computer vision algorithms for my application, so I need the the camera calibration files of the T265. I know that this camera is previously calibrated, but for the algorithms I need the intrinsic and extrinsic parameters. Do you know, where can I find the calibration file? Obviously, I can recalibrate the camera by myself, but I would like to avoid it if the calibration file is accessible.
Thank You!
Renata
MartyG
Intrinsics and extrinsics of the T265 were exposed from SDK version 2.20.0 onward. Below is an example using both to render a virtual object in the fisheye frame:
https://github.com/IntelRealSense/librealsense/tree/master/examples/ar-basic
MartyG
A sample wheel odometry calibration file was added to the T265's documentation a week ago when SDK version 2.21.0 was released.
https://github.com/IntelRealSense/librealsense/blob/master/doc/t265.md#wheel-odometry-calibration-file-format
RNagy
Thanks Marty! Unfortunately, I need the calibration file for the fisheye cameras (e.g. to undistort the fisheye images, etc.). Can you tell me is it accessible or not? It is not a rocket science to calibrate the fisheye cameras but why do it if others did it to me :)
MartyG
RNagy
This is what I needed, thank you so much!
MartyG
You're totally welcome. I'm very glad I could help. :)
