Items with no label
3340 Discussions
Windows update of Intel - net - 19.51.28.1 failed, and now all network adapters are in error status: Code 56
DVanh5
Last successful device driver updates were:
Intel Corporation - Bluetooth - 20.100.6.4
Intel Corporation - Extension - 21.70.0.3
HP Inc. - HIDClass - 2.1.12.1
Synaptics - Mouse - 8/21/2019 12:00:00 AM - 19.5.35.47
Intel - net - 8/26/2019 12:00:00 AM 19.51.24.3
Device ID: pci\ven_8086&dev_095a&subsys_50108086&rev_61
( from the windows update log )
Update failed with Call error code = 0x802440022
Windows update is now disabled, but was at status "last update failed".
but still seems to try to restore the device.
I have tried Windows 10 reset network, removed all network devices, tried with a new wifi dongle, but after every reboot, the intel wifi device is back and in state Code 56.
Each adapter I reinstall either gives timeout when the wifi adapter is enabled, and installs successfully when I delete the wifi (again). But the newly installed network device never comes alive, allways ends up in state Code 56.
The wifi device might indeed be broken ( by the update ? it was functioning perfectly before ). All I want is my other network devices back . First thing seems to stop the wifi from reappearing after restart.
Anyone knows how this device keeps reappearing, or has the same device failure ?
DVanh5
I seem to have a mistake in the error code : Driver installed returned 0X8024200B, Install call error code= 0x80240022 ( info from the windows update log )
nailozaz
Hey did you fix it?
