Items with no label
ZR300 with pcl
DSONG2
I have been trying to capture and save the point cloud data with Intel RealSense.
https://software.intel.com/en-us/articles/using-librealsense-and-pcl-to-create-point-cloud-data?language=en-us&https=1 Use LibRealSense and Point Cloud Library (PCL) to Create Point Cloud Data | Intel® Software
The article above helped me a lot working with R200.
Recently I bought new ZR300 and tried the same code, but it is not working.
It prints out 'segmentation fault (core dumped)' and shuts down the viewer.
As I have googled through 'pcl segmentation fault error', it says it is a known issue with pcl, and they got many solutions.
I tried all the solutions but, still same. R200 works, but ZR300 does not.
I believe it is not any issues related to this: https://github.com/PointCloudLibrary/pcl/issues/619 Segfault on app start using Trusty Beta with packaged PCL · Issue # 619 · PointCloudLibrary/pcl · GitHub
I wonder if anyone has succeed integrating librealsense with pcl using ZR300.
Does PCL support ZR300?
I am trying under the condition below :
Ubuntu : 16.04
librealsense : 1.12.1
PCL : 1.8.1
TLe29
Hi Daeun,
My ZR300 works perfectly with pcl. Please see the attached image.
Could you elaborate your setup?
DSONG2
Hi Tuan,
thank you for the response.
May I ask you what information I should provide you about the setup?
I mentioned the package version I have installed above, and I used the same source code and CMakeLists.txt from the link.
