Items with no label
3341 Discussions
align-depth2color
NeuroGalaxy
Could you explain what does the below line of code means or do.
source from:
http://docs.ros.org/kinetic/api/librealsense2/html/align-depth2color_8py_source.html
bg_removed = np.where((depth_image_3d > clipping_distance) | (depth_image_3d <= 0), grey_color, color_image)
If I want to split the bg_removed into two parameters, for example to x and y. How can I do this? I tried:
x,y = np.where((depth_image_3d > clipping distance)&(depth_image_3d <=0))
but I am getting Value error: "too many values to unpack (expected 2)"
Alexandra_C_Intel
Hi NeuroGalaxy, Thank you for your interest in the Intel RealSense cameras. The code line removes background - Sets pixels further than clipping_distance to grey. Regarding your second question, can you please tell me what data do you want in your x, y variables? What specifically are you trying to do? Regards, Alexandra
NeuroGalaxy
Thanks for explaining the line of code. I understand it now.
I was trying to calculate the distance using the depth information. If I convert it to X,Y and find the mean of this variables (X,Y), will it display the distance in meters?
Alexandra_C_Intel
Hi NeuroGalaxy, You can use this example to get the distance: https://github.com/IntelRealSense/librealsense/tree/master/examples/C/distance Regards, Alexandra
NeuroGalaxy
Thank you. Is it possible to get this code in Python?
Alexandra_C_Intel
