Items with no label
3341 Discussions
are SR300 measures totally wrong?
FLeac
Hello, I using the SR300 as a 3D Scanner. Unfortunatelly i found that all the items i get from it have totally wrong measures.
The file attached is a fast (and not so accurate) example, but still a valid one. http://www.filedropper.com/book http://www.filedropper.com/book
Apart from the fact that the surface is totally inaccurate (probably because the book was glossy), if you use any measure tools for 3d objects, you will see that the scanned book is around 30x24.
In reality the original book is exactly 27.6x22.9 cm.
Did anyone else find that the measure are wrong? Do you have a solution? I am missing something? The book was scanned with the provided 3D Scan example in the SDK.
You're welcome, Francesco. If you wish to continue our interactions through email, just fill out this form: https://supporttickets.intel.com/?lang=en-US . Once you submit your email case, we'll proceed to close this community thread and continue with support through email.
-Sergio A
