Items with no label
3341 Discussions
cvGetWindowHandle identifier not found
CHipg
Hi all,
I am following the guide from https://github.com/IntelRealSense/librealsense/tree/master/wrappers/opencv# windows here to install and run the openCV wrapper examples. I'm successfully building opencv (64 bit) and librealsense (64 bit) but when I try and run one of the examples, Visual Studio cannot find cvGetWindowHandle.
Has anyone else run into this issue?
Thanks!
Hello c_h_r_i_s,
Thank you for your contacting Intel® RealSense™ Technology support.
For future references, your ticket number is 03386423. Please keep this number handy in case you are asked for it.
In order to further assist you we need you to provide us with the Logs generated at the moment of the error that can be found on the "CMakeFiles" folder.
We will be looking forward for your reply.
Josh B.
Intel Customer Support
CHipg
I'm not sure I quite understand. I don't get an error during the CMake process. That gets configured and generated fine. The error is when I try to build the rs-imshow project inside Visual Studio.
Chris
Hello c_h_r_i_s,
Thank you for your reply.
In order to further assist you we need you to provide us with the following information:
• Do you get the error when you tried to build the sample in Visual Studio or run the sample from Visual Studio?
• Does this error happen with any other samples?
• We will appreciate if you can send us screenshots of the error.
Josh B.
