Items with no label
exposure level
LPaul2
Hi folks,
Does librealsense provides any APIs for adjusting SR300 IR camera's exposure level/parameters ?
Thank you !
MartyG
A Librealsense script called cpp-config-ui contains code for adjusting the exposure. Lines 378 to 397 of the script should be particularly interesting to you.
https://github.com/IntelRealSense/librealsense/blob/master/examples/cpp-config-ui.cpp librealsense/cpp-config-ui.cpp at master · IntelRealSense/librealsense · GitHub
Although the script uses auto-exposure, you should be able to convert it to manual exposure control by changing
case RS_OPTION_COLOR_ENABLE_AUTO_EXPOSURE: return set_pu(handle, subdevice, ct_unit, UVC_CT_AE_MODE_CONTROL, value ? 2 : 1); // Modes - (1: manual) (2: auto) (4: shutter priority) (8: aperture priority)
to
case RS_OPTION_COLOR_EXPOSURE: return set_pu(handle, subdevice, ct_unit, UVC_CT_AE_MODE_CONTROL, value ? 2 : 1); // Modes - (1: manual) (2: auto) (4: shutter priority) (8: aperture priority)
LPaul2
Hi MartyG,
Thanks for your reply,
i've checked the example cpp-config-ui, it shows a demo to control the exposure for RGB camera,
Does IR camera as well provides some APIs like that ?
Thank you
MartyG
I believe Librealsense's IR control options mostly relate to the R200 model of camera. Instead, the SR300 camera is provided with commands to control the camera's range automatically. These include:
sr300_auto_range_enable_motion_versus_range
sr300_auto_range_enable_laser
sr300_auto_range_min_motion_versus_range
sr300_auto_range_max_motion_versus_range
sr300_auto_range_start_motion_versus_range
sr300_auto_range_min_laser
sr300_auto_range_max_laser
sr300_auto_range_start_laser ,
sr300_auto_range_upper_threshold
sr300_auto_range_lower_threshold
It has the accompanying note: Configures SR300 depth auto-range setting. Should not be used directly but through the \c rs_apply_ivcam_preset method in rsutil.h.*/
