Items with no label
3341 Discussions
how to save images by using SetFileName() without compression
GWANG20
Hi all,
Now i am working on save real sense R200 camera streaming images. but i encountered a problem. i tried to use the SetFileName() function to save rgb images and
depth images. and i thought it is compressed by default. but i want to save without compress.
Windows Registry Editor Version 5.00[HKEY_CURRENT_USER\SOFTWARE\Intel\RSSDK\FileRecording]"DisableH264Compression"=dword:0"H264_QPI"=dword:8"DisableLZOCompression"=dword:0
the above information is from realSense R2 document , the chapter File Compression(experimental). i set DisableH264Compression"=dword:1, "DisableLZOCompression"=dword:1. which i thought should disable the compression. but after i store the image to file, then playback the image. the content is different. i go over every pixel and check the pixel value before record and after read back. So i thought maybe compression lead to some information loss.
does anyone have idea about that?
Hi Crowe,
Thanks for your interest in the Intel RealSense Platform.
We appreciate all the information provided, we would like to investigate a little bit more and as soon as we find useful information we'll let you know.
-Yermi
Hi Crowe,
Thanks for your patience. As you have mentioned, setting the "DisableH264Compression" and "DisableLZOCompression" to 1 will disable the compression, and noted that setting "H264_QPI" to 0 would be the minimum compression. Additionally, disable the compression imposes huge burden on the system and this requirement makes most spinning disks and certain slow SSD inapplicable for file recording, also, this feature is experimental so it is not fully supported and may have bugs.
Hope this information helps.
-Yermi
