Items with no label
3341 Discussions
how to set advanced settings for rs400 in cpp
JSchl4
I want to set advanced settings on my D415 in c++.
How do I do that exactly?
I tried to do something like, but of course it doesn't work:
void enable_device(rs2::device dev, rs2::context ctx)
std::lock_guard lock(_mutex);
std::string serial_number(dev.get_info(RS2_CAMERA_INFO_SERIAL_NUMBER));
if (_devices.find(serial_number) != _devices.end())
return; //already in
// Ignoring platform cameras (webcams, etc..)
if (platform_camera_name == dev.get_info(RS2_CAMERA_INFO_NAME))
return;
// Create a pipeline from the given device
rs2::pipeline p;
rs2::config c;
c.enable_stream(RS2_STREAM_DEPTH, depthWidth, depthHeight, RS2_FORMAT_Z16, depthFps);
c.enable_stream(RS2_STREAM_COLOR, -1, colorWidth, colorHeight, RS2_FORMAT_RGB8, colorFps);
c.enable_device(serial_number);
// Start the pipeline with the configuration
rs2::pipeline_profile profile = p.start(c);
auto depth_sensor = profile.get_device().first();
// general settings
depth_sensor.set_option(RS2_OPTION_EXPOSURE, 62520);
depth_sensor.set_option(RS2_OPTION_LASER_POWER, 360);
// advanced
auto advanced = rs400::advanced_mode(dev);
while (!advanced.is_enabled()) {
advanced.toggle_advanced_mode(true);
std::cout << "toggled advanced mode for " << serial_number << ", have to sleep" << std::endl;
usleep(5000); // the device will reconnect, so we have to wait a bit and then init the device again
auto devices = ctx.query_devices();
for (auto device : devices) {
if (device.get_info(RS2_CAMERA_INFO_SERIAL_NUMBER) == serial_number) {
dev = device;
advanced.load_json(advancedOptions); // advanced options are exported from realsense-viewer
what am I missing?
Hello jrkb,
To enable the Advance mode on your D415 camera please follow the instructions on the following link:
https://github.com/IntelRealSense/librealsense/releases
Juan N.
JSchl4
Hello Juan,
thanks for your answer.
I tried to find more information on the github wiki, but I couldn't find any, so my hope was to get more detailed support here.
In the meantime I figured out a way to do it. Apparently I was only missing to enable the camera again after reconnecting it.
After running that once, the whole `while (...) {..}` is never called again, and advanced mode directly accessible from start.
I guess this is intended behavior.
Somehow I can't set any settings individually with e.g. `STDepthControlGroup` ..
Loading a complete json does work though.
I still doubt that this is the best way to do it, and indeed I found an interesting link here:
https://github.com/IntelRealSense/librealsense/blob/02aeec770d23b3f8a364f1800e3c5faaaa7d0482/doc/rs400_advanced_mode.md librealsense/rs400_advanced_mode.md at 02aeec770d23b3f8a364f1800e3c5faaaa7d0482 · IntelRealSense/librealsense · GitHub
I'll get more into it, and hope that I don't brick the cameras on the way...
